Hi, auch nach langem suchen hab ich nichts gefunden, das mir bei meinem
problem hilft, daher ein weiterer post.
Ich habe die Display implementierung in ein modul gepackt:
nur leider bekomme ich auf dem Display nichts außerCode:/* 240 x 180 LCD "lcd.c" */ #include <avr/io.h> #include <util/delay.h> #include "lcd.h" // P R O T O T Y P E N void lcd_init(void); void lcd_putc(char sign); void lcd_data(void); void lcd_commando(void); void lcd_reset(void); void lcd_status(void); void lcd_clear_ram(void); void lcd_clear(void); // G L O B A L E V A R I A B L E N uint8_t LCD_DATA; uint8_t LCD_CMD; uint8_t LCD_STATUS; void lcd_init(void) { //LCD Reset lcd_reset(); // Adress Pointer setzen (0x0000) LCD_DATA = 0x23; lcd_data(); LCD_DATA = 0x01; lcd_data(); LCD_CMD = 0x24; lcd_commando(); //TEXT HOME ADDRESS LCD_DATA = 0x00; lcd_data(); LCD_DATA = 0x00; lcd_data(); LCD_CMD = 0x40; lcd_commando(); // GRAPHIC HOME ADDRESS LCD_DATA = 0x02; lcd_data(); LCD_DATA = 0x00; lcd_data(); LCD_CMD = 0x42; lcd_commando(); //TEXT AREA LCD_DATA = 0x14; lcd_data(); LCD_DATA = 0x00; lcd_data(); LCD_CMD = 0x41; lcd_commando(); //GRAPHIC AREA LCD_DATA = 0x14; lcd_data(); LCD_DATA = 0x00; lcd_data(); LCD_CMD = 0x43; lcd_commando(); // Offset Pointer setzen LCD_DATA = 0x02; lcd_data(); LCD_DATA = 0x00; lcd_data(); LCD_CMD = 0x22; lcd_commando(); //DISPLAY MODE //0x97 is the appropriate commando (text, cursor blink) LCD_CMD = 0x9C; lcd_commando(); //MODE SET LCD_CMD = 0x80; lcd_commando(); //CURSOR_DEFINIEREN //2 line cursor: LCD_CMD = 0xA2; lcd_commando(); //CURSOR POINTER SETZEN LCD_DATA = 0x00; lcd_data(); LCD_DATA = 0x00; lcd_data(); LCD_CMD = 0x21; lcd_commando(); } void lcd_reset(void) { ENABLE_RESET; _delay_us(10); // pull RST up DISABLE_RESET; } void lcd_commando(void) { //wait until proper status is available do { lcd_status(); } while (LCD_STATUS != MASK_1); //set config for commando WRITE_PORTA; WRITE_PORTB; ENABLE_COMMANDO; ENABLE_WRITE; DISABLE_READ; // make COMANDO available on DATAPORT PORTA = LCD_CMD; CHIP_ENABLE; _delay_us(DELAY_DATA_COMMAND); CHIP_DISABLE; } void lcd_data(void) { //wait until proper status is available do { lcd_status(); } while (LCD_STATUS != MASK_1); //set config for data WRITE_PORTA; WRITE_PORTB; ENABLE_DATA; ENABLE_WRITE; DISABLE_READ; // make DATA available on DATAPORT PORTA = LCD_DATA; CHIP_ENABLE; _delay_us(DELAY_DATA_COMMAND); CHIP_DISABLE; } void lcd_status(void) { //make porta input to read READ_PORTA; WRITE_PORTB; // prepare controllines according to POWERTIP Datasheet ENABLE_READ; DISABLE_WRITE; //chip enable CHIP_ENABLE; //portb sends commando ENABLE_COMMANDO; _delay_us(1); //save status from port to var LCD_STATUS = PINA; CHIP_DISABLE; DISABLE_READ; LCD_STATUS &= (0x03); } void lcd_putc(char sign) { LCD_DATA = sign - 0x20; lcd_data(); LCD_CMD = 0xC0; lcd_commando(); }
hyroglyphen, regelmäßige streifen oder einfach garnichts zu sehen.
Das Display ist ein Powertip 240 x 128 Pixel Display.
Kann mir da jemand helfen ? Was mach ich falsch ?
Zitieren
Lesezeichen
