siehst du da irgndwo einen Fehler ?Code:__task void main() { init_hw_uart(); // 19200 @3.686 MHz __enable_interrupt(); while(1); } void init_hw_uart() { // Set Baudrate UBRRH = 0x00; UBRRL = 0x0B; // Enable receiver and transmitter UCSRB |= (1<<RXEN)|(1<<TXEN)|(1<<RXCIE); // Set frame format: 8data bit , 1 Stop Bit UCSRC |= (1<<UCSZ1)|(1<<UCSZ0); } void transmit_byte(unsigned char data) { // Put data into buffer, sends the data UDR = data; } #pragma vector=USART_RXC_vect __interrupt void UART_RX_interrupt(void) { DDRB |= (1<<PB0); // Status LED initialization PORTB ^= (1<<PORTB0); // toggle status LED unsigned char data; data = UDR; //receive data transmit_byte(data); // echo data }![]()
Zitieren
Lesezeichen
