							hallo,
'working with atmega8 and lm75
Declare Sub Showtemperatur()
Config Serialout = Buffered , Size = 60
Const Lm75slavewrite = &H90
Const Lm75slaveread = &H91
Dim Lm75high As Byte
Dim Lm75low As Byte
Dim Temperatur As Integer
Dim Nachkommastelle As String * 2
'don't forget to define scl and sda pins !!
Config Sda = Portc.1
Config Scl = Portc.0
     I2cinit
Start:
     Call Showtemperatur                                    'this line was missing from Grillmeister Markus program
     Print Temperatur ; Nachkommastelle
     Wait 2
     Goto Start
   I2cstart
   I2cwbyte Lm75slaveread
   I2crbyte Lm75high , Ack
   I2crbyte Lm75low , Nack
   I2cstop
   If Lm75high > 127 Then
      Temperatur = Lm75high And 127
      Temperatur = Not Temperatur
      Incr Temperatur
   Else
   End If
   Lm75low = Lm75low And 128
   If Lm75low > 0 Then
       Nachkommastelle = ",5"
   Else
      Nachkommastelle = ""
   End If
   'Print Temperatur ; Nachkommastelle
End Sub
		- Neue Themen erstellen: Nein
		- Themen beantworten: Nein
		- Anhänge hochladen: Nein
		- Beiträge bearbeiten: Nein
	Foren-Regeln
Lesezeichen
