Hallo ich müsste den RS232 Ausgang meines Controllers AT90S2313
von 8N1 auf 8E1(also Even) in Bascom umstellen.Hier das Testprogramm.
Läuft aber nicht.Hat jemand eine Idee.Die Buffer wurden schon zurückgesetzt.
$regfile = "2313def.dat" ' specify the used micro
$crystal = 3686400 ' used crystal frequency
$baud = 9600 ' use baud rate
$hwstack = 40 ' default use 32 for the hardware stack
$swstack = 40 ' default use 10 for the SW stack
$framesize = 40 ' default use 40 for the frame space
Config Com1 = Dummy , Synchrone = 0 , Parity = Even , Stopbits = 1 , Databits = 8 , Clockpol = 0
'setup to use a serial output buffer
'and reserve 20 bytes for the buffer
Config Serialout = Buffered , Size = 5
'It is important since UDRE interrupt is used that you enable the interrupts
Enable Interrupts
Print "Hello world"
Print "test1"
Wait 1
'notice that using the UDRE interrupt will slown down execution of waiting loops like waitms
Print "test"
End
