Fehlermeldung beim starten von rviz
Kennt sich jemand mit der Fehlermeldung evtl. aus? rviz lässt sich bei mir nicht starten , aber gazebo funktioniert. Grafikkarte on board(intel GMA 4500 MHD)
fehlermeldung bei starten von rviz :
auto-starting new master
process[master]: started with pid [31943]
ROS_MASTER_URI=http://localhost:11311
setting /run_id to 78165382-1e68-11e1-83b3-90004e158d56
process[rosout-1]: started with pid [31957]
started core service [/rosout]
process[joint_state_publisher-2]: started with pid [31970]
process[robot_state_publisher-3]: started with pid [31972]
process[rviz-4]: started with pid [31974]
The program 'rviz' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadDrawable (invalid Pixmap or Window parameter)'.
(Details: serial 22 error_code 9 request_code 136 minor_code 3)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
[rviz-4] process has died [pid 31974, exit code 1].
log files: /home/monk/.ros/log/78165382-1e68-11e1-83b3-90004e158d56/rviz-4*.log
^C[robot_state_publisher-3] killing on exit
[joint_state_publisher-2] killing on exit
[rosout-1] killing on exit
[master] killing on exit
shutting down processing monitor...
... shutting down processing monitor complete
done
