ich habe jetzt versucht, Mxt's verlinktes NN auf dem esp8266 zum Laufen zu kriegen, aber die Routinen führen dazu, dass der esp dauernd rebootet (wschl wegen watchdog timeout) - fast wie ich es befürchtet habe.
Nach ein paar delay(1) zwischendrin rebootet er nicht mehr, aber es dauert nun sehr lange - mal gucken.....
http://robotics.hobbizine.com/arduinoann.html
- - - Aktualisiert - - -Code:// A Neural Network for Arduino
// http://robotics.hobbizine.com/arduinoann.html
// 2-layer Backpropagation net
// modified by HaWe
// version 0.0.2
#include <math.h>
#define REPORT_N 100
* Network Configuration - customized per network
const int PatternCount = 10;
const int InputNodes = 7;
const int HiddenNodes = 8;
const int OutputNodes = 4;
const float LearningRate = 0.3;
const float Momentum = 0.9;
const float InitialWeightMax = 0.5;
const float Success = 0.00040;
const byte Input[PatternCount][InputNodes] = {
{ 1, 1, 1, 1, 1, 1, 0 }, // 0
{ 0, 1, 1, 0, 0, 0, 0 }, // 1
{ 1, 1, 0, 1, 1, 0, 1 }, // 2
{ 1, 1, 1, 1, 0, 0, 1 }, // 3
{ 0, 1, 1, 0, 0, 1, 1 }, // 4
{ 1, 0, 1, 1, 0, 1, 1 }, // 5
{ 0, 0, 1, 1, 1, 1, 1 }, // 6
{ 1, 1, 1, 0, 0, 0, 0 }, // 7
{ 1, 1, 1, 1, 1, 1, 1 }, // 8
{ 1, 1, 1, 0, 0, 1, 1 } // 9
const byte Target[PatternCount][OutputNodes] = {
{ 0, 0, 0, 0 },
{ 0, 0, 0, 1 },
{ 0, 0, 1, 0 },
{ 0, 0, 1, 1 },
{ 0, 1, 0, 0 },
{ 0, 1, 0, 1 },
{ 0, 1, 1, 0 },
{ 0, 1, 1, 1 },
{ 1, 0, 0, 0 },
{ 1, 0, 0, 1 }
* End Network Configuration
int i, j, p, q, r;
int ReportEvery_n;
int RandomizedIndex[PatternCount];
long TrainingCycle;
float Rando;
float Error;
float Accum;
float Hidden[HiddenNodes];
float Output[OutputNodes];
float HiddenWeights[InputNodes+1][HiddenNodes];
float OutputWeights[HiddenNodes+1][OutputNodes];
float HiddenDelta[HiddenNodes];
float OutputDelta[OutputNodes];
float ChangeHiddenWeights[InputNodes+1][HiddenNodes];
float ChangeOutputWeights[HiddenNodes+1][OutputNodes];
void setup(){
Serial.begin(115200);
delay(1000);
randomSeed(analogRead(3));
ReportEvery_n = 1;
for( p = 0 ; p < PatternCount ; p++ ) {
RandomizedIndex[p] = p ;
void loop (){
* Initialize HiddenWeights and ChangeHiddenWeights
for( i = 0 ; i < HiddenNodes ; i++ ) {
for( j = 0 ; j <= InputNodes ; j++ ) {
ChangeHiddenWeights[j][i] = 0.0 ;
Rando = float(random(100))/100;
HiddenWeights[j][i] = 2.0 * ( Rando - 0.5 ) * InitialWeightMax ;
* Initialize OutputWeights and ChangeOutputWeights
for( i = 0 ; i < OutputNodes ; i ++ ) {
for( j = 0 ; j <= HiddenNodes ; j++ ) {
ChangeOutputWeights[j][i] = 0.0 ;
OutputWeights[j][i] = 2.0 * ( Rando - 0.5 ) * InitialWeightMax ;
Serial.println("Initial/Untrained Outputs: ");
toTerminal();
* Begin training
for( TrainingCycle = 1 ; TrainingCycle < 2147483647 ; TrainingCycle++) {
* Randomize order of training patterns
for( p = 0 ; p < PatternCount ; p++) {
q = random(PatternCount);
r = RandomizedIndex[p] ;
RandomizedIndex[p] = RandomizedIndex[q] ;
RandomizedIndex[q] = r ;
Error = 0.0 ;
* Cycle through each training pattern in the randomized order
for( q = 0 ; q < PatternCount ; q++ ) {
p = RandomizedIndex[q];
* Compute hidden layer activations
Accum = HiddenWeights[InputNodes][i] ;
for( j = 0 ; j < InputNodes ; j++ ) {
Accum += Input[p][j] * HiddenWeights[j][i] ;
Hidden[i] = 1.0/(1.0 + exp(-Accum)) ;
* Compute output layer activations and calculate errors
for( i = 0 ; i < OutputNodes ; i++ ) {
Accum = OutputWeights[HiddenNodes][i] ;
for( j = 0 ; j < HiddenNodes ; j++ ) {
Accum += Hidden[j] * OutputWeights[j][i] ;
Output[i] = 1.0/(1.0 + exp(-Accum)) ;
OutputDelta[i] = (Target[p][i] - Output[i]) * Output[i] * (1.0 - Output[i]) ;
Error += 0.5 * (Target[p][i] - Output[i]) * (Target[p][i] - Output[i]) ;
* Backpropagate errors to hidden layer
Accum = 0.0 ;
delay(1);
for( j = 0 ; j < OutputNodes ; j++ ) {
Accum += OutputWeights[i][j] * OutputDelta[j] ;
HiddenDelta[i] = Accum * Hidden[i] * (1.0 - Hidden[i]) ;
* Update Inner-->Hidden Weights
delay(1);
ChangeHiddenWeights[InputNodes][i] = LearningRate * HiddenDelta[i] + Momentum * ChangeHiddenWeights[InputNodes][i] ;
HiddenWeights[InputNodes][i] += ChangeHiddenWeights[InputNodes][i] ;
ChangeHiddenWeights[j][i] = LearningRate * Input[p][j] * HiddenDelta[i] + Momentum * ChangeHiddenWeights[j][i];
HiddenWeights[j][i] += ChangeHiddenWeights[j][i] ;
* Update Hidden-->Output Weights
ChangeOutputWeights[HiddenNodes][i] = LearningRate * OutputDelta[i] + Momentum * ChangeOutputWeights[HiddenNodes][i] ;
OutputWeights[HiddenNodes][i] += ChangeOutputWeights[HiddenNodes][i] ;
ChangeOutputWeights[j][i] = LearningRate * Hidden[j] * OutputDelta[i] + Momentum * ChangeOutputWeights[j][i] ;
OutputWeights[j][i] += ChangeOutputWeights[j][i] ;
* Every 1000 cycles send data to terminal for display
ReportEvery_n = ReportEvery_n - 1;
if (ReportEvery_n == 0)
Serial.println();
Serial.println();
Serial.print ("TrainingCycle: ");
Serial.print (TrainingCycle);
Serial.print (" Error = ");
Serial.println (Error, 5);
toTerminal();
if (TrainingCycle==1)
ReportEvery_n = REPORT_N-1;
else
ReportEvery_n = REPORT_N;
* If error rate is less than pre-determined threshold then end
if( Error < Success ) break ;
Serial.println ();
Serial.println();
toTerminal();
Serial.println ();
Serial.println ();
Serial.println ("Training Set Solved! ");
Serial.println ("--------");
Serial.println ();
Serial.println ();
ReportEvery_n = 1;
void toTerminal()
Serial.println();
Serial.print (" Training Pattern: ");
Serial.println (p);
Serial.print (" Input ");
for( i = 0 ; i < InputNodes ; i++ ) {
Serial.print (Input[p][i], DEC);
Serial.print (" ");
Serial.print (" Target ");
Serial.print (Target[p][i], DEC);
Serial.print (" ");
Serial.print (" Output ");
Serial.print (Output[i], 5);
Serial.print (" ");
Update:
konnte inzwischen ein paar delays wieder rausnehmen, klappt immer noch und ist wieder ein bisschen schneller.
jawohl, er hat das Training geschafft:
Code:TrainingCycle: 5375 Error = 0.00040
Training Pattern: 0
Input 1 1 1 1 1 1 0 Target 0 0 0 0 Output 0.00775 0.00009 0.00431 0.00639
Training Pattern: 1
Input 0 1 1 0 0 0 0 Target 0 0 0 1 Output 0.00092 0.00465 0.00439 0.99653
Training Pattern: 2
Input 1 1 0 1 1 0 1 Target 0 0 1 0 Output 0.00244 0.00013 0.99975 0.00190
Training Pattern: 3
Input 1 1 1 1 0 0 1 Target 0 0 1 1 Output 0.00038 0.00698 0.99533 0.99567
Training Pattern: 4
Input 0 1 1 0 0 1 1 Target 0 1 0 0 Output 0.00609 0.99732 0.00555 0.00466
Training Pattern: 5
Input 1 0 1 1 0 1 1 Target 0 1 0 1 Output 0.00173 0.99669 0.00484 0.99655
Training Pattern: 6
Input 0 0 1 1 1 1 1 Target 0 1 1 0 Output 0.00034 0.99465 0.99296 0.00011
Training Pattern: 7
Input 1 1 1 0 0 0 0 Target 0 1 1 1 Output 0.00005 0.99232 0.99417 1.00000
Training Pattern: 8
Input 1 1 1 1 1 1 1 Target 1 0 0 0 Output 0.99110 0.00002 0.00254 0.00019
Training Pattern: 9
Input 1 1 1 0 0 1 1 Target 1 0 0 1 Output 0.99327 0.00678 0.00002 0.99424
