Impulslänge einer Fernsteuerung messen
nach dem Einlesen in die Programmierung habe ich versucht, mit dem nachfolgenden Programm die Länge der Impulse von meiner Fernsteuerung zu messen. Das ist mein kleines Einstiegsprojekt 8-[
'----- Titel -------------------------------------------------------------------
' Module.......: ServoSignal.bas
' Purpose......: Measure and show radio control pulse length
'----- Settings ----------------------------------------------------------------
$regfile = "2313DEF.Dat"
$crystal = 4000000
Config PortB = Output
Config PinB.0 = input 'used for RC signal
Config PortD = Output
config Timer0 = timer , prescale = 64
on timer0 Mispulse
'----- Functions ---------------------------------------------------------------
Declare Sub GetPulse(PulseLength As byte )
'----- Variables ---------------------------------------------------------------
Dim PulseLength As byte 'stores current reading of RC signal
Dim PulseLast As byte 'stores last reading of RC signal
Dim PulseError as Byte 'stores errors, given by timer0
'Dim PulseLengthMin As Byte
'Dim PulseLengthMax As Byte
'----- Initialization ----------------------------------------------------------
PulseLength = 0
PulseLast = 0
PulseError = 0
PortB = &B00000000
'PulseLengthMax = 0
'PulseLengthMin = 0
enable Timer0
enable Interrupts
'----- Program -----------------------------------------------------------------
do
call GetPulse(PulseLength)
'PulseLast = PulseLength
PortD = &B00000000 'delete last value of pulse length
select case PulseLength
case 000 to 036 : PortD.0 = 1
case 037 to 072 : PortD.1 = 1
case 073 to 108 : PortD.2 = 1
case 109 to 144 : PortD.3 = 1
case 145 to 180 : PortD.4 = 1
case 181 to 216 : PortD.5 = 1
case 217 to 252 : PortD.6 = 1
end select
'print PulseLast
loop
end 'end program
'----- Subroutines -------------------------------------------------------------
Sub GetPulse(PulseLength As byte)
PulseLength = 0
WaitForPulse:
!sbis PinB,0 'jump if bit is set = pulse is positive
!rjmp WaitForPulse
WaitForLow: 'run loop until pulse gets negative
Incr PulseLength 'add 1 in variable PulseLength
!sbic PinB,0 'jump if bit is not set = pulse is negative
!rjmp WaitForLow
Timer0 = 0
End Sub
Mispulse:
'print "Timer0 active"
incr PulseError
'Print "Fehler #" ; PulseError
PortB.1 = 0
wait 1
PortB.1 = 1
return
Im Bascom-Simulator läuft es einwandfrei, aber im real existierenden Leben tut es absolut nicht das, was es soll. De facto ist keine Reaktion auf das Eingangssignal festzustellen; d.h. trotz Variation der Eingangs-Impulslänge am Servotester reagieren die am PortD verbundenen LED's nicht.
Deshalb weiß ich jetzt erst einmal nicht weiter... ](*,) Kann hier jemand mit einem Tipp helfen (ich werde das Gefühl nicht los, dass ich einfach etwas Grundlegendes übersehen habe)?
Beste Grüße
Jürgen
